Wheels and tyres
17 Jan 2019 18:18 #200990 by jackonlyjack
Replied by jackonlyjack on topic Wheels and tyres
Cremator1 wrote: Jack u buy them lol go on lol what was wrong with the ones I sent u
The one's you posted are for Jakkarta wheels the 60 degree tapper has to be from nut face NO flat insert
  • Cremator1
17 Jan 2019 18:19 - 17 Jan 2019 18:21 #200991 by Cremator1
Replied by Cremator1 on topic Wheels and tyres
Ah ok that was a waste of money then gv24 from this site said I could use them great lol
Last edit: 17 Jan 2019 18:21 by Cremator1.
17 Jan 2019 18:27 #200993 by Lambert
Replied by Lambert on topic Wheels and tyres
And you're going to keep pouring good money after bad until you've measured the actual wheel you're fitting, there's too many variations of nut seats on aftermarket wheels.
  • Cremator1
17 Jan 2019 18:34 #200994 by Cremator1
Hi but I don’t no how to measure it
17 Jan 2019 18:45 #200995 by Lambert
Get a protractor just a cheap plastic school one and rest it across both edges of the nut hole in the wheel, then with a suitable straight edge that is narrow enough to fit through the hole and rest on the chamfer. Use this to read off the angle on the protractor. If the straight edge only touches on two points when through the hole and you can see daylight in a small semi circle then the seat is a radius and measuring that is more involved.
17 Jan 2019 18:48 #200996 by jackonlyjack
Just found some modulars in the usa and it says 60 degree
ckspacing (in)
4.000 in.
Beadlock Functional
No
Beadlock Included
No
Center Cap Included
No
Hub Centric
No
Lug Nut Seat Style
Conical seat - 60 degree
Manufacturers Wheel Series
Bart Wheels D Trucker Series
Primary Wheel Color
Black
Quantity
Set of 4
Recommended Valve Stem
7/16 in. pull-through or bolt-on
Valve Stems Included
No
Wheel Construction
2-piece
Wheel Diameter
15 in.
Wheel Finish
Gloss
Wheel Material
Steel
Wheel Width (in)
8.000 in.
