Allgrip spinng wheel method of 2019 Jimny..
- Crumbs
01 Dec 2018 14:47 #198476
by Crumbs
Replied by Crumbs on topic Allgrip spinng wheel method od 2019 Jimny..
Hi Gadget.
Can you give me the link to the accessories catalogue you mention please?
Thank you.
Thank you.
01 Dec 2018 17:28 #198485
Replied by Riccy on topic Allgrip spinng wheel method od 2019 Jimny..
You can sort of simulate a rear locker in a standard current jimny by gently applying the hand brake, which might have been enough to get you out of the snow that day
the only really practical option for a proper selectable locker is the ARB's at nearly £1000 a end, plus the compressor, switches, fitting, HD shafts, etc. I believe Yakuza has just fitted some of the chinese copy of the ARBs and is happy with them, but dont know how much cheaper they are.
- Crumbs
01 Dec 2018 17:57 #198488
by Crumbs
Hi Riccy.
Someone, I believe on this forum, sawed his hand brake leaver right down the middle and one half operated the left rear brake and the other half the right rear brake. An excellent solution. He could operate both rear brakes together or individually.
Technology took its time to provide a solution which was extremely costly and very complex and yet does exactly the same job.
01 Dec 2018 18:31 #198490
Have a search on 'fiddle' brakes. Its not exactly sawing the lever in two, but works in much the same way. Oldskool tractors have two brake pedals, one for each rear side, or both for a brown trouser stop :laugh:.
It would be possible to fit a second 'lever' near the handbrake that worked left to right to brake the rear wheels as desired. The handbrake cable splits about where the cup holder is to each side :whistle:
- Crumbs
01 Dec 2018 19:01 #198493
by Crumbs
Three gear levers may confuse the MOT tester.
My MOT tester was confused by the button pressing to work the transfer box on my generation 3 Jimny.
Didn't want to test the rolling road braking in 4WD.
Yes I know there are little lights but he thought it might be was front wheel drive!
01 Dec 2018 19:01 #198494
by sniper
Replied by sniper on topic Allgrip spinng wheel method od 2019 Jimny..
The Quaife ATB differential is supposed to work very well with these electronic brake traction systems. I remember reading about them when I got my diff. Seamless control and and less judder when in use, if I remember correctly.
Riccy, I remember jack using his hand brake to force a bit of traction across the axle, when we were climbing that goat trail in the lakes...
sniper
sniper
Time to create page: 0.198 seconds
