Light wiring
- Mole
25 Nov 2018 19:53 #198160
by Mole
Replied by Mole on topic Light wiring
So would this be the right way round? This stuff never sinks in
- Thank you received: 227
26 Nov 2018 04:36 #198165
by zukebob
Replied by zukebob on topic Light wiring
As Facade said. The white and colored stripe to pin 86 and the solid red (high beam) wire to 85. That provides current, exciting the relay (switching it) when the high beam is on. Assuming there is no pin 87a, connect your fused lead from the battery to pin 30 and your spot light lead to pin 87. Run the ground from your spots to an appropriate ground.
- Mole
26 Nov 2018 06:21 #198167
by Mole
Ok thanks will try that thanks all for your patience
26 Nov 2018 10:08 #198171
by zukebob
No patience required. We all try to help. Let me also clarify my post. It would be better to say that you would tie into the white and striped wire and the red wire with leads from the 86 and 85 relay pins.
Just post again if you have problems.
- Mole
26 Nov 2018 10:12 #198172
by Mole
Thank you will have a little time to mess with it tomorrow afternoon so will report back then Or ask for more help one or the other haha
26 Nov 2018 16:54 #198183
by kirkynut
Replied by kirkynut on topic Light wiring
The quickest way for me to answer is look here as I did it recently:
www.bigjimny.com/index.php/forum/8-my-ji...-continues?start=264
Time to create page: 1.290 seconds
