Leaky rear shock
- shortylumber
22 Jun 2018 08:16 #193722
by shortylumber
Leaky rear shock was created by shortylumber
So get a shout from the father to check under car as he thinks petrol is leaking...thankfully not but it does look like the rear right shock is. Looks like both have seen better days.
So rather than do odd jobs in just going to replace front and back suspension. Tempted by a 2inch lift because why not if I'm changing it I may as well change it properly.
Aside from the kit, brakelines, bushings, is there anything else I need to be aware of or should change whilst getting it done?
22 Jun 2018 08:52 #193724
Replied by mlines on topic Leaky rear shock
To some extent it depends on what kit you get as some (such as my 2" Trailmaster) include everything you need in one kit.
Additional tip however, if you are thinking about it then get outside and spray penetrating oil on the bolts now (and every day onwards) so that once you have decided and ordered you will have half a chance of getting the bolts undone.
- shortylumber
22 Jun 2018 09:16 #193725
by shortylumber
Replied by shortylumber on topic Leaky rear shock
I had seen the trailmaster one on the shop and liked the look of it, first one I've seen so will have a look around for any other full kit examples just to get an idea of things
Oh yeah I shall do, been meaning to do that for a while now, just have to raid the garage for wd40
- X8GGY
22 Jun 2018 10:05 #193726
Replied by X8GGY on topic Leaky rear shock
And an insurance quote being as you’re modifying it...
22 Jun 2018 10:31 #193727
Replied by yakuza on topic Leaky rear shock
Caster correcting bushings is not included in the kit i think, correct me please anyone. I think they should be.
After it is lifted you will need to correct your caster angles to regain the stability on road you where used to before the lift.
Without correction to the caster, the car will not self center after turning as well as before.
- X8GGY
22 Jun 2018 10:40 #193728
I personally don’t think the TrailMaster lift needs castor correction?
I’ve fitted two now, the latter on my daily driver, fitted with a Steering Damper but no castor correction, it drives just fine...
Time to create page: 0.203 seconds
