Leaky rear shock
  • shortylumber
22 Jun 2018 18:45 #193750 by shortylumber
Replied by shortylumber on topic Leaky rear shock
Kind of asked for that didn't I? Aha
I get that, was just curious if the kit differed in say brake length part or something else due to having abs or not, still very new to all this
22 Jun 2018 19:39 #193755 by X8GGY
Replied by X8GGY on topic Leaky rear shock
The only difference is the non-ABS kit has a little L-shaped bracket to lift the brake bias valve’s spring up so that it’s level again after the lift...
  • helijohn
22 Jun 2018 19:44 #193756 by helijohn
Replied by helijohn on topic Leaky rear shock
mlines wrote: get outside and spray penetrating oil on the bolts now (and every day onwards) so that once you have decided and ordered you will have half a chance of getting the bolts undone.
I used to use plus gas which I liked but having worked on elderly motors all my life I have found soaking with pen. oil even after days does little to help. WD40 is weedy. I even used plasticine to make a reservoir of the stuff to soak in where possible with no effect. Breaker bars, blowtorches and air weapons do help a lot soooooooo can anyone suggest a effective pen. oil??
  • shortylumber
23 Jun 2018 09:34 #193761 by shortylumber
Cheers S200KYS.
Better get saving I think, as either way a few bits of stuff need doing
Time to create page: 0.637 seconds
