Car Engine Temperature - overheating?
- apayne
08 May 2018 21:11 #192530
by apayne
Car Engine Temperature - overheating? was created by apayne
Hi there, I've got a 2001 Jimny with the M13A engine and I have a feeling it's overheating at the moment. If I take the car out for a 30 minute drive, as soon as I come back the engine head / valve cover is roasting hot - to the point where it's untouchable. The temperature gauge needle is sitting comfortably just below centre but I'm sure the engine head shouldn't be heating up to the point where it's boiling hot / untouchable?
The top radiator hose is very hot which must mean the water pump is working and flowing around the engine. The radiator is topped up with 50/50 coolant and expansion tank is full.
What else would you suggest checking? Blocked radiator? Flush radiator? Thermostat? Although the coolant wouldn't flow around the top hose if the thermostat was broken, right?
All suggestions are appreciated.
- Thank you received: 1982
09 May 2018 04:22 #192533
Replied by Lambert on topic Car Engine Temperature - overheating?
If i have been working Ermintrude hard I wouldn't want to touch the engine, plenty hot enough to burn. If you have a live data reader see what the actual temperature is in degrees, it's likely to be in the 80 to 90 degree range.
- Jimx5
09 May 2018 05:59 #192537
by Jimx5
Replied by Jimx5 on topic Car Engine Temperature - overheating?
It's the bottom hose you need to check, if it is cool (a lot cooler) than the top hose it's either a failed thermostat or the water pump.
- apayne
09 May 2018 07:10 #192540
by apayne
The bottom hose is much cooler than the top hose, but isn't this how it's supposed to be? I thought the hot coolant came from the engine through the top hose, cools down in the radiator and then the cooler coolant pumped back into the engine via the bottom hose. Thanks
Replied by apayne on topic Car Engine Temperature - overheating?
Jimx5 wrote: It's the bottom hose you need to check, if it is cool (a lot cooler) than the top hose it's either a failed thermostat or the water pump.
09 May 2018 07:50 #192541
Replied by mlines on topic Car Engine Temperature - overheating?
I use an Autel MaxiTrip gauge connected into the diagnostic socket, this gives me a continuous reading, Here it showing in Fahrenheit (I had just installed it) but it happily shows in Centigrade. And as stated it is usually in the high 80s and low 90s
- Thank you received: 923
09 May 2018 09:38 #192542
Replied by X8GGY on topic Car Engine Temperature - overheating?
Oooh, where do we get one of them Martin?
Just tried eBay and Amazon, but didn't find any...?
Time to create page: 1.238 seconds
