Car Engine Temperature - overheating?
- Thank you received: 923
10 May 2018 12:45 #192580
Replied by X8GGY on topic Car Engine Temperature - overheating?
On the plus side though, it was a UK seller, it's been despatched and is due tomorrow...
10 May 2018 17:32 #192584
by Busta
If the temperature gauge is reading in the middle, and there are no symptoms other than the engine being hotter to the touch than you expected, I'd be willing to suggest everything is completely normal and you are being paranoid.
Replied by Busta on topic Car Engine Temperature - overheating?
apayne wrote: Any advice for the overly hot engine? I've drained the radiator and also going to check the thermostat is working fine.
- apayne
10 May 2018 17:44 #192586
by apayne
Thanks. I've got an OBD2 reader now that shows me coolant temp readings etc. so will flush the rad, put new coolant in and take it for a run whist checking the readings. If it's above the 80-90 degrees range I'll come back to you
Replied by apayne on topic Car Engine Temperature - overheating?
10 May 2018 19:36 #192588
by kirkynut
Replied by kirkynut on topic Car Engine Temperature - overheating?
I bought the Maxitrip years ago soon after Martin showed his for the first time and now have a Scanguage 2.
My temperature in my 2000 twin cam has always been 89'c around town until I stop in traffic, when it goes up to 92'c until I pull off or rest my foot on the throttle to speed up the pump and get the colder coolant through from the radiator.
When I'm at speed with high revs or on a long incline, it might go to 93'c or at tops 95'c.
So there's your bench marks.
10 May 2018 23:17 #192590
Replied by helijohn on topic Car Engine Temperature - overheating?
I like this. My Celerio only has a warning light for engine coolant temp so would this work as a coolant temp gauge for it?
Jezz wrote: Or cheaper Chinese version of the same thing.
11 May 2018 08:56 #192594
by Jezz
It's been fettled just a tad.
Replied by Jezz on topic Car Engine Temperature - overheating?
I believe so. Dave S200KYS has ordered one of these, So give him a shout and when he gets his i'm sure he will be happy to confirm for you.
