Damaged a lead whilst replacing fan belt
  • phillw
27 Apr 2018 20:04 - 27 Apr 2018 20:13 #192232 by phillw
Hi,
I wondered if i could ask for some help.
Tonight i was completing the replacement of a crank pulley. I decided to replace my belts whilst i had the radiator off. I'm kicking myself now, but i have broken off the plug part of a lead that goes into the engine block whilst trying to tighten my alternator belt with a pinch bar. I must have just caught it and the plug was very corroded and brittle. I hadn't noticed it was damaged until I took it out for a spin around the block and after 100m's everything died and I've had to abandon it on the pavement at the end of my street! The immobiliser light came on when the engine turned off.
The plug is in a tight little spot behind the alternator and the flex comes up and joins onto another loom heading back towards what I presume is the main loom.
Any advise on the cable name and its function would be much appreciated
I should have said its a 52 plate 16v m13A engine
Last edit: 27 Apr 2018 20:13 by phillw.
27 Apr 2018 20:34 #192233 by mlines
Sounds like the crankshaft sensor
  • phillw
27 Apr 2018 21:24 #192234 by phillw
Replied by phillw on topic Re:Damaged a lead whilst replacing fan belt
Thanks for that. ill try and get a photo tomorrow in the daylight. it looks like the male plug is also damaged so i might need to replace that also.
  • phillw
28 Apr 2018 08:46 #192242 by phillw
Replied by phillw on topic Damaged a lead whilst replacing fan belt
just taken a look at the damaged sensor. I would say it is a cam shaft sensor after seeing one online. my other issue is the plug part is knackered also. would i need a replacement lead complete or can I refit a new male plug by re crimping the wiring ?
Thanks in advance.
28 Apr 2018 09:59 - 28 Apr 2018 10:02 #192245 by mlines
Camshaft sensor is normally located at the rear of the engine at the top
They look very similar
www.bigjimny.com/store/crankshaft-sensor-p138.html
Last edit: 28 Apr 2018 10:02 by mlines.
  • phillw
28 Apr 2018 10:40 #192246 by phillw
This is the lead it isn't to the rear of the engine but in a tight spot to the side of the alternator. i can't get my phone in the there to show the position of the plug into the block its so tight
Time to create page: 0.187 seconds
