Spring Spacer Help
09 Mar 2018 09:20 #190163 by furo
Replied by furo on topic Spring Spacer Help
Hi folks,
So I checked the distances between tyres and arches this morning and it is still leaning to the drivers side by 1cm front and rear (although you can't tell by looking - it looks much better). So I will leave the rear spacer in.
On my way into work this morning there was a dull pinging sound coming from the drivers side (front and rear) when going over speedbumps/potholes, which must be coming from the spacers. Is this common or is it something to be worried about?
09 Mar 2018 20:48 #190191 by robs5230
Replied by robs5230 on topic Spring Spacer Help
furo wrote: Hi folks,
Honestly I'd remove the spacer on the rear. Its doing no good there. The noise I guess is the suspension creaking as its working against itself. Get both spacers on the top of the front right hand spring where they need to be. Everything will be just as intended then. Replacements spring are the same length at the back and at the front the drivers side one is longer than the passenger one to eliminate lean.
As said before, the lean is diagonal rear left hand side to front right.
standard jimny - for now
09 Mar 2018 21:14 #190193 by furo
Ok thanks, I'll take that rear spacer out.
In terms of the sound it was a very distinctive twanging noise that clearly came from the front axle when the front wheels hit the speedbump and the rear axle when the rear wheels hit. Hopefully taking the rear spacer out will help.
09 Mar 2018 23:16 #190198 by Busta
Replied by Busta on topic Spring Spacer Help
When you put the springs back in did you make sure they bottom coil was orientated correctly in the seat?
09 Mar 2018 23:19 #190200 by furo
How do you know if it is correctly orientated? The lift kit instructions didn't mention that.
10 Mar 2018 05:06 #190206 by mlines
Replied by mlines on topic Re:Spring Spacer Help
The spacer should have a cut surface shaped to take the end of the spring and to stop the spring rotating
Time to create page: 4.445 seconds
