Spring Spacer Help
08 Mar 2018 20:08 #190147
by furo
Spring Spacer Help was created by furo
Hi folks,
I installed two 15mm spring spacers today to mitigate a case of Jimny-lean. I put the front one under the spring but before doing the rear one I checked online and it seems they are meant to go at the top of the spring, so that's what I did. The front one seems very secure and there were no issues on a brief test run. Do I need to change the front spacer so that it is on top of the spring or is it fine to leave it on the bottom?
Many thanks
Many thanks
08 Mar 2018 20:15 #190148
Replied by jackonlyjack on topic Spring Spacer Help
I have never used one but i would think at the bottom it could suffer premature wear do to movement being greater at the axle end
I would move it to the top
08 Mar 2018 20:24 #190151
Replied by mlines on topic Re:Spring Spacer Help
Top
They are cut and shaped to fit the top. They will move around and even fall out from the bottom
08 Mar 2018 21:40 - 08 Mar 2018 21:46 #190152
by robs5230
standard jimny - for now
Replied by robs5230 on topic Spring Spacer Help
I thought it was just the front right hand corner to cure the lean ? Why have you put one on the rear ? If you looked at the vehicle before fitting the spacers, the front right and corner would be down and the rear left hand corner be up. The rear right side may have looked slightly down but would pick up when the front right hand corner is spaced.
Have a read of this. I did one 6 years or so ago.
www.bigjimny.com/index.php/forum/7-jimny...39879-the-jimny-lean
Last edit: 08 Mar 2018 21:46 by robs5230.
08 Mar 2018 22:10 #190153
by Busta
Replied by Busta on topic Spring Spacer Help
What Robs says. The lean is a diagonal thing, you won't need one on the rear.
08 Mar 2018 22:22 #190154
by furo
Replied by furo on topic Spring Spacer Help
Thanks for the help guys, I've sorted the front spacer now.
Rob/Busta - Right, thanks I didnt realise that. It's done now - I'll check distances between arch and tyres tomorrow and if they are close I'll leave it in.
Time to create page: 0.274 seconds
