4wd on snow covered road
- doddy
04 Mar 2018 17:15 #189925
by doddy
4wd on snow covered road was created by doddy
hello
I have just changed form a Mitsubishi pajero to an 07 jimny
reading the manual it seems to say don't drive on roads in 4wd mode (it is a confusing manual)
my question is am ok to drive on tarmac in 4wd mode
thanks in advance john
04 Mar 2018 17:20 #189926
Replied by mlines on topic Re:4wd on snow covered road
No you are not.
It is part time 4WD with no centre differential so can only be used when there is some way of slip occurring in the system
The following user(s) said Thank You: doddy
04 Mar 2018 19:12 #189934
by Busta
Replied by Busta on topic 4wd on snow covered road
If the tarmac road is covered in snow or ice then it's fine. But tarmac, wet or dry, is too grippy to allow the wheelslip required to keep the 4x4 system happy.
- Young Pretender
04 Mar 2018 19:20 - 04 Mar 2018 19:21 #189935
by Young Pretender
Replied by Young Pretender on topic 4wd on snow covered road
Was just going to say the same. You can engage 4WD on snow covered roads no problem. But there's always some judgment because if moving from snow covered roads to roads that have been cleared of snow you want to enage normal 2WD.
Have a read up on 'transmission wind up' which will explain why. Essentially your 4WD is relatively less sophisticated than modern 4WD in that all 4 wheels have to turn the same number of rotations. Because the front wheels can turn left/right they can rotate at different speeds meaning the front and rear prop shafts that meet in your transfer box are twisting. On a slippery surface they can unwind themselves but not on tarmac.. modern 4x4's have a differential in the transfer box that can unwind.
Last edit: 04 Mar 2018 19:21 by Young Pretender.
- doddy
04 Mar 2018 19:53 #189938
by doddy
Replied by doddy on topic 4wd on snow covered road
thanks for all of the replies
ive just sold an old pajero , with that one you could keep it in 4wd (not diff lock) even if you went on to a road where the snow had cleared .
04 Mar 2018 22:03 #189941
You must have had super select 4WD which mine has. It's a pretty sophisticated four wheel drive. I also have a limited slip diff which I bet yours had. The comments are right.
You really do need to get used to not using 4WD unless you are sure there is good slippage like soggy deep mud. I really noticed axle wind up in my Jimny.
How do you like the transition from Paj to Jimny? My Paj is a 1992 and still going strong. I just feel vilified cos it is an old diesel.
Replied by helijohn on topic 4wd on snow covered road
doddy wrote: thanks for all of the replies
Time to create page: 0.193 seconds
