Permanent 4x4
- Venter
20 Sep 2017 15:38 - 20 Sep 2017 16:22 #184274
by Venter
Replied by Venter on topic Permanent 4x4
Rockwatt seemed to think the Niva t-box was a good idea. Not sure if he had a solution to the l/h r/h output problem, but might be worth hitting him up about it. He had a handful of Niva t-boxes lying around his workshop a few years ago when I spoke to him about it.
He seemed to think the main obstacles were refabbing new mounts, and getting HD front shafts / CVs installed to cope with added stress of permanent 4x4.
Last edit: 20 Sep 2017 16:22 by Venter.
- Thank you received: 1875
20 Sep 2017 16:13 #184275
Replied by Lambert on topic Permanent 4x4
Hmmm. This is making permanent rwd an increasingly likely proposition.
- Venter
20 Sep 2017 16:25 #184277
by Venter
c'mon, we need a guinea pig, might just start a new craze amongst Jimny owners and you'd be able to say it was you who started it
- OllieNZ
20 Sep 2017 19:10 #184282
by OllieNZ
Replied by OllieNZ on topic Re:Permanent 4x4
To fit the lh drop case you basically have to mirror image the drive train.
-Flip the axles
-Move the fuel tank
-Reroute the exhaust
-Mod the tubular cross members to clear the drive shafts
Maybe some other stuff I've missed....
I'm going to fit an lt230 to mine (along with yota axles and auto box with a 250hp VAG 1.8t 20 valve up front)
-Flip the axles
-Move the fuel tank
21 Sep 2017 06:39 - 21 Sep 2017 06:42 #184285
by Busta
Or mount the transfer box at the required angle, drill a new oil drain hole and bend the shift levers so they come up through the floor in the right place? Which would seem an easier option. It's just a box with some gears in. It doesn't know which way 'up' is.
Replied by Busta on topic Re:Permanent 4x4
OllieNZ wrote: To fit the lh drop case you basically have to mirror image the drive train.
-Flip the axles
-Move the fuel tank
Last edit: 21 Sep 2017 06:42 by Busta.
21 Sep 2017 08:49 #184286
Replied by Lambert on topic Re:Permanent 4x4
No ollieNZ is right. To get the correct orientation you would have to rotate the box 180 through the vertical axis ant then drive it through the wrong side of the input flange, essentially turning it into a custom one off, not a bolt on and therefore outside my abilities.
Time to create page: 0.198 seconds
