Permanent 4x4
  • OllieNZ
21 Sep 2017 11:18 #184295 by OllieNZ
Replied by OllieNZ on topic Re:RE: Re:Permanent 4x4
Busta wrote:
OllieNZ wrote: To fit the lh drop case you basically have to mirror image the drive train.
-Flip the axles
-Move the fuel tank
-Reroute the exhaust
-Mod the tubular cross members to clear the drive shafts
Maybe some other stuff I've missed....
I'm going to fit an lt230 to mine (along with yota axles and auto box with a 250hp VAG 1.8t 20 valve up front)
Or mount the transfer box at the required angle, drill a new oil drain hole and bend the shift levers so they come up through the floor in the right place? Which would seem an easier option. It's just a box with some gears in. It doesn't know which way 'up' is.
Unfortunately alot of boxes do know which way is up, the angle of the box will affect the internal lubrication system. You may be able to permanently tilt it up to 10 degrees without issue and some (np series boxes come to mind) can be flipped 180 but outside of this range it's definitely something that needs to be considered.
It may be worth checking out but to do it with the lada box it would most likely require a large section of the trans tunnel to be extended underneath the drivers seat to clear the box.
22 Sep 2017 09:09 #184323 by Keithy
Replied by Keithy on topic Permanent 4x4
I had a look at the lada transfer and figured it'd be too much work..
I settled on modifying the standard Jimny transfer and inserting a locking diff in there.....got the spare transfer and as yet haven't had time to measure it up and see if I can do it....probably billet a new casing for the rear and make the locker...couple of bearings...who knows....it's on the list as the Swift sport turbo is going together over the winter and I "need" full time 4X4 then :D
  • OllieNZ
22 Sep 2017 10:13 #184325 by OllieNZ
Replied by OllieNZ on topic Re:RE: Permanent 4x4
Keithy wrote: I had a look at the lada transfer and figured it'd be too much work..
You could attack the lt230 with a mill and reduce the weight of it.....
I hear the ashcroft atb is a very good bit of kit for them.
24 Sep 2017 06:53 #184412 by Keithy
It was mentioned to me at KORC yesterday regards the LT230 tranny box......I figured from memory they were around the 2000kg mark......seems they are around the 45kg mark......I may have a look if the ratios are suitable.......Ashcroft atb looks a nice addition and not too spendy!
24 Sep 2017 07:08 #184413 by Riccy
Replied by Riccy on topic Permanent 4x4
  • OllieNZ
24 Sep 2017 08:31 #184415 by OllieNZ
Replied by OllieNZ on topic Re:Permanent 4x4
1.2:1 ish high from a disco and 1.667:1 high from a defender and low is 3.32:1 regardless. Ashcroft also do a range of different high ratio gearsets up to 1:1.
The early disco 2's had an electrically actuated center diff lock (same case still can be converted back to stick shift) that only engaged in 4lo.
The later diso 2's did away with the center diff lock mechanism altogether in favour of electronic traction control using the brakes.
Check out the thread on pirate4x4 "I blew up my lt230 at koh" some really good gen and very positive reviews on both the toughness and improved handling provided by the atb including one racing with it behind a 500hp ls v8
