Where are all the cv posts
- TomDK
28 Jan 2017 20:33 #177449
by TomDK
Replied by TomDK on topic Where are all the cv posts
I think you're the first one I've ever seen mentioning that it's easy to remove a shaft from a CV
28 Jan 2017 20:44 #177450
Replied by mlines on topic Where are all the cv posts
You do not need to break the circlip, the trick is to hold the joint very straight when driving it off.
But if they are pretty much joined together then what makes you think it is an issue because generally they explode into bits when they fail
28 Jan 2017 20:45 #177452
And pitting of the ball is of no consequence, just rub it down with filler.
What exactly are the symptoms you are trying to cure?
28 Jan 2017 20:57 #177454
by Keithy
A piece of tube to slide over the shaft and mate with the hub of the joint slide it in a downward direction until it hits the floor and you have it removed....brinell free.....strip clean reassemble.
Replied by Keithy on topic Where are all the cv posts
TomDK wrote: I think you're the first one I've ever seen mentioning that it's easy to remove a shaft from a CV
- markmano
29 Jan 2017 07:45 #177459
by markmano
Replied by markmano on topic Where are all the cv posts
I tried clamping shaft in vice about 4"down ie not on seal surface then put spacers upto bottom of cv so when I levered stub shaft it was pulling in an upwards motion. I'll try a bit harder next time now I know it's a snap ring. Cv not blown to pieces just one piece of cage broke but it's broke for sure. Can't I just put 6 ball cvs in and matching shafts if they're easier to find. Are these stronger than the 8 ball type?
Thanks for all the help I'm new to Jimnys but it looks like I'll be learning a lot!
Also I didn't mark up vacuum pipes but assume I can trace them to find correct one.
Might remove ABS ring too as it's daft I need to strip bearing to replace the 4 hub bolts. I'll be putting high tensile bolts back in there too those things were soft as muck!!
29 Jan 2017 11:18 #177467
by facade
Replied by facade on topic Where are all the cv posts
In The Olden Days I just used to hold the driveshaft upright in one hand, and whack the joint down with a mallet and they would fly off. (usually missing the carefully positioned cardboard box- good job I'm not a bomber pilot)
The following user(s) said Thank You: Keithy
Time to create page: 0.187 seconds
