Where are all the cv posts
- markmano
28 Jan 2017 16:16 #177419
by markmano
Where are all the cv posts was created by markmano
I must be going mad!
Popped the nearside cv and thought I'd order one easily but
1.Cv and shaft appear to be joined together by witchcraft, you can see they're seperate but you can't split em.
2.There's no spare CV joints on this site or not what I can find anyway.
3.There's no Haynes manual for a Jimny
4.There's no posts from anyone with similar problem.
54 plate auto. Cv is 8 ball bearing type passenger side with long shaft.
- hannah-jg
28 Jan 2017 17:19 #177429
by hannah-jg
Replied by hannah-jg on topic Where are all the cv posts
To remove the cv off the shaft....
i find putting the shaft end into a piece of metal pipe thats longer than the shaft then dropping it vertically so the end of the pipe hits the floor and "pushes up" and it will pop the CV off, just watch it doesn't fly off and hit you
or loose the small clip.
Haynes manual- can't help with I'm afraid
CV ebay has them or local motor factors, i would assume on a 54 plate you want the one with less splines..... i think from memory, but I'm sure someone will come along and correct me
28 Jan 2017 19:04 - 28 Jan 2017 19:08 #177440
Replied by mlines on topic Where are all the cv posts
How to change them is here in the Wiki - its always worth looking in the Wiki.
www.bigjimny.com/mediawiki/index.php/CV_...CV_joint_information
The Wiki has links to the CVs which are in the BigJimny Store (although just awaiting further stock)
The Type 1 is available overnight www.bigjimny.com/store/cv-joint-type-1.html
The Type 2 is due in again soon www.bigjimny.com/store/cv-joint-type-2.html
Last edit: 28 Jan 2017 19:08 by mlines.
- markmano
28 Jan 2017 20:00 #177441
by markmano
Replied by markmano on topic Where are all the cv posts
Ok great so I have to force shaft out of cv to break it off hidden circlip? That's gonna do the circling groove no good at all I might just cut the cv so I can find this clip. I'm considering getting replacement axle though as no oil came out when I stripped it meaning crown wheel and pinions will have suffered, hub bearing grease was very poor too and steering knuckle is pitted meaning it was probably left standing for a long time at some point. Overhauling each side is looking like £150 each now at this rate and that's if I'm lucky enough to find the super rare 8 ball cvs that are in mine. Bit gutted to be honest.
- TomDK
28 Jan 2017 20:08 #177443
by TomDK
Replied by TomDK on topic Where are all the cv posts
28 Jan 2017 20:20 #177444
by Keithy
Replied by Keithy on topic Where are all the cv posts
Easy enough to free the cv from the snap-ring.....kinda gives a clue with it's name no?
Time to create page: 0.263 seconds
