Lockin hubs conversion
  • helijohn
03 Nov 2016 18:19 #174217 by helijohn
Replied by helijohn on topic Lockin hubs conversion
jimmyp wrote: I thought i did mate not sure what i have done with them , anyways sorted now , i fitted the hubs today is there a way i can tell to make sure everything is locking as it shud , ? Do i need to sort the flasing 4x4 light for it to work ? Thanks
The hubs work when you get out and select.
The flashing light can be silenced see here
www.bigjimny.com/index.php/forum/7-jimny...-light-with-pictures
  • jimmyp
03 Nov 2016 18:55 #174225 by jimmyp
Replied by jimmyp on topic Lockin hubs conversion
Cheers mate will sort that thanks for the info
  • jimmyp
06 Nov 2016 14:25 #174326 by jimmyp
Hey guys so am on doing this flasing 4x4 light i have followed the link ,but my not sure what its called circle thing under the fuse box has the wires moulded into it no plug comes out do i just cut the white connector off the end n join the wires up , thanks
  • jimmyp
06 Nov 2016 18:20 #174342 by jimmyp
  • TomDK
06 Nov 2016 18:53 #174343 by TomDK
Replied by TomDK on topic Lockin hubs conversion
For future projects.
You don't need those spacers. Just cut off the onthreaded part of the bearing lock nuts of with a grinder.
  • helijohn
06 Nov 2016 18:57 #174344 by helijohn
jimmyp wrote:
If it is like mine was as I recall you simply need to bridge the terminals in the plug on the end of those leads. It is the same as cutting and joining but I didn't cut mine in case I wanted to refit the vacuum system. So I made a link to bridge them.
Time to create page: 0.171 seconds
