Belt tension meter
helijohn wrote: My problem is that I don't like to over tighten so I tend to let the belt run too loose.:blush:
Me too
After that incident with the front pulley coming apart, I tighten them just enough to stop the squealing in the dry.
If you fancy getting the calculator and ruler out with your 'phone
mlines wrote: I was always told that being able to twist the belt 90 degrees only was a good test
Me too and with some motors they say X" of deflection - I've had the engineer's rule out and spring balances but really it's a right game with some alternators.
Me too
Never mind the cell phone, I wonder if I can use my Snark tuner. Clip it on the belt or something and twang away. First I need to calculate the note needed.
Between finger and thumb for a single V belt....works for me still!mlines wrote: I was always told that being able to twist the belt 90 degrees only was a good test
Nothing sounds worse than a timing belt too tight.....at the stealers we had all manner of setting tools for belts....never used em...
What about serpentine belts?
