Belt tension meter
  • helijohn
21 Sep 2016 18:03 #172652 by helijohn
Belt tension meter was created by helijohn
No eBay APP ID and/or Cert ID defined in Kunena configurationI am looking at belt tension gauges/meters. What do folks use?
This has been recommended.
  • mickt
21 Sep 2016 18:59 #172657 by mickt
Replied by mickt on topic Belt tension meter
Are the figures for the tension of the belts in the Jimny manual then?
21 Sep 2016 19:13 #172658 by Rhinoman
Replied by Rhinoman on topic Belt tension meter
For most belts I use my finger, for the timing belt on the G13/G16 engines I use a cheap spring balance.
  • helijohn
21 Sep 2016 19:29 #172661 by helijohn
Replied by helijohn on topic Belt tension meter
Rhinoman wrote: For most belts I use my finger, for the timing belt on the G13/G16 engines I use a cheap spring balance.
Me too but now I am beginning to wonder.
22 Sep 2016 11:33 #172681 by facade
Replied by facade on topic Belt tension meter
The "modern" way is with an optical gauge.
You point it at the belt and twang the belt, it then measures the frequency the belt vibrates at.
Just like the cricket, this would be brilliant if only the manufacturers told you the frequency to expect (which depends on the mass of the belt, the tension and how far between the pulleys.)
I suppose you send the car to the stealers for adjustment with a thumb :lol: , then immediately take a measurement, write it down and keep adjusting back to that one.
There is an "app" for these new fangled mobile phones that claims to be a tension meter, I think you have to be very quiet and pluck the belt, then it measures the frequency with the microphone.
  • helijohn
22 Sep 2016 11:48 #172683 by helijohn
facade wrote: The "modern" way is with an optical gauge.
That sounds (excuse the pun) absolutely brilliant. I learn every day. I expect the garage tool is very costly.
And you are right, getting detailed info on this particular DIY job is a PITA.
My problem is that I don't like to over tighten so I tend to let the belt run too loose.:blush:
Time to create page: 1.007 seconds
