alternator squealing
01 Mar 2016 19:01 #163226 by minibbb
Replied by minibbb on topic Re:alternator squealing
ewanm77 wrote: eurocarparts has then in the sale just now
Really?! How much?
  • ewanm77
01 Mar 2016 19:10 - 01 Mar 2016 19:23 #163228 by ewanm77
Replied by ewanm77 on topic Re:alternator squealing
Think they were 66 there on there eBay shop
Ignore me I was looking at the wrong pulley
m.mister-auto.co.uk/en/crankshaft-pulley...sjnQ3an_RxoC-Zbw_wcB
Last edit: 01 Mar 2016 19:23 by ewanm77.
01 Mar 2016 19:35 #163230 by minibbb
Is this the right part? Seems suspiciously cheap mind you
  • ewanm77
01 Mar 2016 19:38 #163231 by ewanm77
I'm not 100% sure someone will know exactly
01 Mar 2016 19:48 #163232 by kirkynut
Replied by kirkynut on topic Re:alternator squealing
Change the belt and set the tension right and see if that fixes it. The belt is likely due replacement anyway. Do the other belt while you're at it.
  • Back in Black
02 Mar 2016 13:19 #163255 by Back in Black
Replied by Back in Black on topic alternator squealing
Mine was doing exactly what you describe. I took the alternator belt off and ran the engine and the squeal went away.
So looked closer at the alternator and found the adjuster bar was cracked and this had caused the alternator to run on a slight angle. Replaced the bar and for a month no noise - eventually it came back as the alternator bearing had given out!!
Got a replacement alternator from James (j999pre) no more squeaking :)
Does your engine bay appear to have developed black dandruff? With the alternator running on worn a bearing the pulley will wobble and the belt rubs on the sides creating lots of tiny burnt rubber dust!
Time to create page: 0.281 seconds
