alternator squealing
03 Mar 2016 18:21 #163305 by minibbb
Replied by minibbb on topic Re:alternator squealing
mlines wrote:
minibbb wrote:
Is this the right part? Seems suspiciously cheap mind you
That part lists as only for the WagonR+
Thanks Martin- that's what happens when you rely on Google!
Ordered the genuine part which was £124 posted. Going to the garage tomorrow but it's annoying as I want to rule the alternator bearing out as the suspect too!
Squealing is horrendous and also the belt is powdering near to the alternator
  • Decklandpt
07 Mar 2016 11:02 #163441 by Decklandpt
Replied by Decklandpt on topic Re:alternator squealing
so,had a look in the weekend.
it's definitly the bearing. the crank pulley was fine, no cracks in the rubber bond, and no off-axis spinning
sprayed some wd-40, it helped as long as it was being spayed, but as it was turning it was being spat out, so i turned of the engine, added some more wd-40 and left it to rest, tomorrow i'll drive it to work and see how it goes. do you guys reckon i'll need a new alternator or can the bearing be replaced?
07 Mar 2016 11:44 #163444 by facade
Replied by facade on topic alternator squealing
If you can get the alternator apart, you should be able to remove the bearing and match it either from the size, or the numbers on it.
I couldn't get the casing apart, I was sure that it would break, but as you don't want the front bearing, you could warm the casing round the bearing and try.
Of course, you won't be able to drive the car until the alternator is replaced, and you won't be able to exchange it in pieces.
  • Decklandpt
08 Mar 2016 13:24 #163496 by Decklandpt
Replied by Decklandpt on topic alternator squealing
so, drove it to work today, no noises or squealing, guess i'm gonna be carrying that can of wd-40 with me for a week till i go to the mechanic. damn schedules, cant get off work at a decent hour
Time to create page: 0.150 seconds
