alternator squealing
  • Decklandpt
01 Mar 2016 13:54 #163197 by Decklandpt
alternator squealing was created by Decklandpt
hi guys, need a bit of advice.
my jimny sometimes squeals like mad. happens everytime just after i turn on the engine, within one or two minutes of doing so.
i start it in the parking lot, drive it over to the tool gate, like, 100 meters, and as soon as i stop to wait for it to open, it starts to squeal. i then hit the accelerator (in idle) and as soon as it hits just above 3000rpm it stops and doesn't happen again until the next time i start the engine after a while parked.
the first times it happened i felt a bit of a bunt rubber smell, but not anymore.
had a small battery, the previous owner ran a 30ah 300a battery instead of a 45ah.
i figured it was the small and old battery that was putting some strain on the alternator so i changed it. still, no luck
yesterday i decided to open the bonnet and see where the squeal was comming from. turned on the engine, turned everything on, heater, lights, wipers, demister, the lot, and sure as shit, it started to make some noise.
turnes out it's comming from the alternator.
it's a grinding noise, like a bust bearing, maybe the moisture from the cold nights makes it squeal in the morning.
so, question time... is it possible to mend the alternator, or do i need a new one?
i've read about the vitara v6 alternator upgrade... is it plug and play or do i need to change something else?
thanks
  • mickt
01 Mar 2016 17:46 #163210 by mickt
Replied by mickt on topic alternator squealing
Which engine is it? If its the dual cam m13 a It generally means the crankshaft pulley is on the way out but check the belts first.
01 Mar 2016 18:06 #163212 by minibbb
Replied by minibbb on topic Re:alternator squealing
mickt wrote: Which engine is it? If its the dual cam m13 a It generally means the crankshaft pulley is on the way out but check the belts first.
Is this the right part Mick?
  • Decklandpt
01 Mar 2016 18:37 #163216 by Decklandpt
Replied by Decklandpt on topic Re:alternator squealing
yeah, that's the part he means
in my case, i'm not sure that's the culprit... the car is a late 2000 with 70k miles on it.
looking at the belts with the engine working, i don't see anything out of axis or strange vibrations on the belts. all i can determine is a grinding noise coming from the alternator.
gets worse when i sap power, by using the windows or lights, for example.
it is a m13a, and yeah, i know about the crank puley issue... is there any other telltale sign related to the pulley? i do notice that when first firing up, it does so with a thud, like, as if something was slightly out of position and caused some resistance. but it has always done that and it never got worse..
  • mickt
01 Mar 2016 18:50 #163220 by mickt
Close inspection of the rubber connecting the inner and outer rims will help. In some cases the pulleys fall apart but in my daughters case there were just tiny cracks in the rubber that caused two belts to give up the ghost. Since replacing the pulley all is well!
  • ewanm77
01 Mar 2016 18:54 #163223 by ewanm77
Replied by ewanm77 on topic alternator squealing
eurocarparts has then in the sale just now
Time to create page: 0.420 seconds
