33 inch tyres
  • Smoggy
14 Jan 2016 15:18 #160341 by Smoggy
Replied by Smoggy on topic 33 inch tyres
The shafts are a larger diameter then Jimny shafts and thus I would expect them to be stronger than the smaller diameter Jimny items assuming that all other things stay the same ie quality of the steel etc. I understood that trail gear 4340 shafts were pretty damn good. Then there is the small issue of the price difference!
  • TomDK
14 Jan 2016 16:15 #160344 by TomDK
Replied by TomDK on topic 33 inch tyres
The shafts you mention. They're 26 spline Trail Gear right? They're exactly the same as the ones for a jimny. Just a bit shorter to fit the narrower samurai axle. No difference in strength.
  • Smoggy
14 Jan 2016 19:59 #160364 by Smoggy
TomDK wrote: The shafts you mention. They're 26 spline Trail Gear right? They're exactly the same as the ones for a jimny. Just a bit shorter to fit the narrower samurai axle. No difference in strength.
Yes thanks Tom. I thought for some reason they were thicker but as you say they are the same. Good job I'm selling them a lot cheaper then 😄
  • TomDK
14 Jan 2016 20:17 #160366 by TomDK
The front axle you have for sale with HD shafts, CVs and airlocker for £600 is a good price, no question :-)
My only concern with axle swaps is if the brackets are 100% straight and correctly welded on so the axles are parallel.
  • RichiesJimny
14 Jan 2016 20:53 #160371 by RichiesJimny
Replied by RichiesJimny on topic 33 inch tyres
Hi Mike correct me if I'm wrong but I thought the Jimny diff in your sj axle was running with sj side gears so you could fit bigger shafts and cv joints than the Jimny uses.
  • TomDK
14 Jan 2016 21:03 #160373 by TomDK
RichiesJimny wrote: Hi Mike correct me if I'm wrong but I thought the Jimny diff in your sj axle was running with sj side gears so you could fit bigger shafts and cv joints than the Jimny uses.
Sj/ jimny side gears from rear axle are needed to fit 26 spline shafts.
Time to create page: 0.255 seconds
