Number plate lights
  • mickt
05 Nov 2015 11:51 #155400 by mickt
Replied by mickt on topic Number plate lights
Not according to the diagram in the handbook. It mentions tail. stop, fog & dome as the lights which have fuses only.
  • 2013gary
06 Nov 2015 09:39 #155532 by 2013gary
Replied by 2013gary on topic Number plate lights
Please let me know how you get on with this as I haven't had reverse lights on mine ever since I got the clutch changed almost a year ago! I'm guessing a switch was left unplugged somewhere.
I completely forgot about them at MOT time but my Jimny still passed. The tester told me that they aren't tested.
  • Zook123
06 Nov 2015 10:45 #155539 by Zook123
Replied by Zook123 on topic Number plate lights
Will do, going to take a look tomorrow to see if it's something simple like the cable becoming unplugged!
  • OllieNZ
06 Nov 2015 12:13 #155543 by OllieNZ
Replied by OllieNZ on topic Re:RE: Number plate lights
Zook123 wrote: Will do, going to take a look tomorrow to see if it's something simple like the cable becoming unplugged!
I'll have a look at the wiring manual when I get home if that'll help?
06 Nov 2015 13:55 - 06 Nov 2015 13:56 #155552 by kirkynut
Replied by kirkynut on topic Re:RE: Number plate lights
It will most likely be the switch. Take the plug off the switch and connect the wires to see if the light comes on. The ignition has to be on obviously and you might have to get a bit of wire and put two blade connectors on to join the wires together via it.
That will tell you that it is the switch if by connecting the wires the lights work as that is the only part you have taken out of the system.
Last edit: 06 Nov 2015 13:56 by kirkynut.
  • OllieNZ
07 Nov 2015 14:22 #155649 by OllieNZ
Replied by OllieNZ on topic Number plate lights
Zook123 wrote: Sounds like it could be the reverse switch then! Before I look at doing the switch is there a fuse for it?
According to the wiring diagram it should have a 10A one, depending on vin either: No 20 'TURN BACK' or No 42 'BACK' and other than that its just the switch. both bulb are earthed independently
Time to create page: 0.808 seconds
