Number plate lights
  • Zook123
03 Nov 2015 17:22 #155278 by Zook123
Number plate lights was created by Zook123
Just noticed I have no number plate lights or reverse lights, is there a fuse for this?
03 Nov 2015 21:47 #155290 by Johnniehec
Replied by Johnniehec on topic Number plate lights
I don, t think it'd be the same fuse, I'm sure the tail lights are on the same wiring as the number plate lights are they still on? More likely to be loose/ corroded/fused bulbs and the wiring connector to the gearbox for the reverse lights.
04 Nov 2015 05:28 #155311 by kirkynut
Replied by kirkynut on topic Number plate lights
As above, sounds like two separate problems!
  • Zook123
04 Nov 2015 08:33 #155320 by Zook123
Replied by Zook123 on topic Number plate lights
Newbie mistake, turns out both of the number plate lights had gone!
Replaced the bulbs and it's now lighting, but can't get the reverse lights to work, i've tried replacing the left with a new bulb, but it still doesn't work.
Do the Jimny's have two reverse lights? I only ask, as all of my previous cars have only one reverse light?
Cheers!
  • OllieNZ
05 Nov 2015 07:12 #155385 by OllieNZ
Replied by OllieNZ on topic Re:Number plate lights
The jimny does use both reverse lights but if you lose one the other should still work.
  • Zook123
05 Nov 2015 07:32 #155387 by Zook123
Sounds like it could be the reverse switch then! Before I look at doing the switch is there a fuse for it?
Time to create page: 0.227 seconds
