Number plate lights
  • Zook123
07 Nov 2015 20:15 #155655 by Zook123
Replied by Zook123 on topic Number plate lights
The plot thickens, it turns out the switch wasn't plugged into anything!
Found the other end, plugged in and.... nothing. Except when you take it out of reverse!
So now i've got the reverse lights on all the time, but not when it goes into reverse!
It appears the plug only works one way, so i've unplugged for now!
08 Nov 2015 04:55 #155676 by kirkynut
Replied by kirkynut on topic Number plate lights
Sounds like the switch might be stuck on so they just unplugged it.
  • fshdck
08 Nov 2015 08:46 - 08 Nov 2015 08:47 #155683 by fshdck
Replied by fshdck on topic Number plate lights
Try WD-40 on the switch and press it several times to clean it. Worked on mine. If not it's around 30 quid from dealers. Try japarts.co.uk They rarely have anything in stock, but order parts and deliver quite quick.
I've used them for original Suzuki parts before and they're ok.
Chances are, the vendor you use might send you the switch for Swift gearbox which is shorter, so always make sure its the right one.
I have one spare lying somewhere in original packaging, so can get you exact part number if you need it.
Last edit: 08 Nov 2015 08:47 by fshdck. Reason: typo
08 Nov 2015 11:03 #155704 by facade
Replied by facade on topic Number plate lights
Watch out when you take the switch out, there is usually a ball bearing underneath it.
Time to create page: 0.674 seconds
