No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Vacuum pipes rusted.
10 Oct 2015 10:05 #153334 by BGBrit
No eBay APP ID and/or Cert ID defined in Kunena configurationVacuum pipes rusted. was created by BGBrit
Having discovered the vacuum pipes look in a bad state, I've decided to replace them with new, and came across these on ebay. Has any one replaced their pipes with this blue silicon pipework. Did you find it was up to the job.
Is it a diificuit job to do ?
Thanks for any feed back..
Tony.
10 Oct 2015 15:23 #153347 by X8GGY
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by X8GGY on topic Vacuum pipes rusted.
Hmmm... I'll have a go at that as mine went recently too...
10 Oct 2015 15:37 #153348 by mlines
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by mlines on topic Vacuum pipes rusted.
If its soft silicon will it not collapse under the vacuum. Surely a rigid or semi-rigid pipe is better?
The following user(s) said Thank You: BGBrit
10 Oct 2015 15:45 #153349 by BGBrit
No eBay APP ID and/or Cert ID defined in Kunena configurationReplied by BGBrit on topic Vacuum pipes rusted.
Hi Martin,
I did write to your store if they could supply me wih new vac pipes a few days ago, I'm having two sets of King pin bearing sent over from you at the moment, will arrive soon to Bulgaria, I just noticed my vac pipes are pretty worn while I was preparing for the King pins bearing work.
I'd rather use orginal parts if you can supply them..As I take your point on soft material.
Cheers
Tony (BGBrit)
10 Oct 2015 17:48 #153357 by mlines
Yes, I don't do these pipes. I was just emphasising to check that they will take the vacuum.
THe vacuum is quite low - 5.7 PSI or 40Kpa is the minimum for the system but I would ask the vendor what the hose is specified to.
10 Oct 2015 18:07 #153360 by mlines
It looks like it is this stuff
www.demon-tweeks.co.uk/performance/vacuu...bing-silicone-rubber
From these people
www.samcosport.com/uk/rp_vacuum_tubing.asp
It looks like people use it for mechanical boost gauges that display between -1 and +2 BAR which is over 14psi of vacuum at the lower extreme which suggests its ok for 5 PSI of vacuum
Time to create page: 0.182 seconds
