sun visor strip
- darthloachie
26 Sep 2015 07:20 #152573
by darthloachie
The latest reactalite have a version that will actually work inside a car, but can only be fitted to single vision lenses, so I had to have the standard version
Replied by darthloachie on topic sun visor strip
facade wrote:
Halford wrote: Facade, already have reactalite specs but don't think you get polaroid with them, could try this though ....
Reactalite don't go dark enough in the car, as they need UV to react to, and the glass windscreen stops most of the UV.
You need a fixed tint.
When the low sun reflects off a flat surface like a wet road, the reflected light is horizontally polarised, the sunglasses are vertically polarised and block this, reducing the glare.
26 Sep 2015 09:21 - 26 Sep 2015 09:23 #152583
by facade
That's worth knowing when I get new glasses next year
Halford was complaining about the low Winter Sun. This causes two problems:
1) it shines straight in your eyes. Always when there is a dangerous manoeuvre to perform (pulling out of a junction, overtaking a parked lorry etc.) :whistle: . Sunglasses, or indeed a tinted visor will reduce this (if you look through the visor)
2) it reflects off wet roads, your flat bonnet etc. causing glare. Polarised glasses reduce, or eliminate this, because they block the reflected light waves.
I tried those eBay flip up clip on polarised glasses, and they work, but the plastic hinge breaks, proper Polaroid ones are north of £20, so I got some prescription polarised sunglasses, which work well.
I suppose I need some night driving glasses now, with a yellow tint, and polarised lenses, but I still have a pair of yellow flip-up ones that aren't broken.
Replied by facade on topic sun visor strip
Last edit: 26 Sep 2015 09:23 by facade.
26 Sep 2015 18:24 #152595
Replied by helijohn on topic sun visor strip
Whereas I used to have to drop the sun visor in winter sun conditions, with the strip in place there is no need. I find a peaked cap is another serious aid and naturally sunspecs especially if the road is wet. Also a raised seat helps; being up in the roof makes such a difference.
26 Sep 2015 20:01 #152597
by gilburton
Replied by gilburton on topic sun visor strip
Anyone tried these things??
Plenty on ebay
Plenty on ebay
- Thank you received: 360
27 Sep 2015 15:27 - 27 Sep 2015 15:29 #152615
by Halford
Replied by Halford on topic sun visor strip
after an hour or so I was quite pleased with the result
:laugh:
must be a bloke thing, why didn't I learn after the previous attempt :dry:
a man's go to know his limitations
:whistle:
still have a little offcut, will maybe try putting it on my specs :S
:laugh:
:whistle:
Last edit: 27 Sep 2015 15:29 by Halford.
27 Sep 2015 15:32 #152616
