sun visor strip
- Thank you received: 360
23 Sep 2015 06:07 #152403
by Halford
sun visor strip was created by Halford
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThe low winter sun is starting to bug me,
so going to try again (tried a couple of years ago and made a total arse),
better luck this time :whistle:
which to get ?
1. one where you Peel film apart from backing
2. or one that simply wets and sticks
thanks for any help in getting the right product
which to get ?
23 Sep 2015 06:25 - 23 Sep 2015 06:26 #152404
Replied by Daniel30 on topic sun visor strip
Wet n stick might be better depending on the product, you can add a little fairy liquid to the spray then you can move it into position a bit better and squeeze all the air bubbles out easier
You can you a little of the solution on the peel and stick aswell to get it into position if you go for that one
Last edit: 23 Sep 2015 06:26 by Daniel30. Reason: Can
- jim
23 Sep 2015 11:03 #152416
by jim
Replied by jim on topic sun visor strip
Hal, I saw on eBay pre cut jimny sunvisor tint. As Daniel said use aa tiny drop of fairy liquid with water in a plant spray allows you to move it about until you got it right.
23 Sep 2015 11:42 - 23 Sep 2015 12:02 #152418
Have a look Halford
pages.ebay.com/link/?nav=item.view&id=221878617621&alt=web
Give the screen a good clean to get the grease and dirt off
Last edit: 23 Sep 2015 12:02 by Daniel30. Reason: added
- Thank you received: 699
23 Sep 2015 16:42 #152435
Replied by jackonlyjack on topic sun visor strip
i fit the solid black type to my fabia washing up liquid and water
leave a few hours then trim edges
BUT have to remove every year for mot because its in the wiper sweep :ohmy:
The following user(s) said Thank You: Halford
23 Sep 2015 17:36 #152440
by facade
Replied by facade on topic sun visor strip
Get a pair of polarised sunglasses, I got prescription ones. You still need the sunvisor to block that glowing ball in the sky, but they take away the glare from the road, worse when wet.
Time to create page: 0.154 seconds
