Brake pedal going almost to the bottom after lift
26 Aug 2015 18:49 #150695
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Brake pedal going almost to the bottom after lift
Have you bled it at the load valve?
Grey pick up Jimny
- Mart3971
26 Aug 2015 21:01 #150716
by Mart3971
Replied by Mart3971 on topic Brake pedal going almost to the bottom after lift
Yes mate with no joy. Turing into a head scratcher.
27 Aug 2015 06:04 #150723
by j999pre
Grey pick up Jimny
Can you borrow an easi bleed from someone and pressure bleed it?
I'm sure your bleeding from nearside rear first then load valve then nearside front the offside front?
Have you checked the new connections for leaks if you fitted longer flexi hoses?
Top up the brake fluid after about 5 pumps when bleeding
Grey pick up Jimny
- skywalker65
- Premium Member
- Thank you received: 20
27 Aug 2015 06:43 #150724
by skywalker65
If in doubt ...... Flat out ??
Replied by skywalker65 on topic Brake pedal going almost to the bottom after lift
Have you checked the rear brakes are adjusted properly. Had all the symptoms you described after over hauling the full brake system on my Subaru Justy.
Turned out rear brakes needed adjusting up
- fozzie
27 Aug 2015 07:41 #150726
by fozzie
Nice one! That makes sense!
Replied by fozzie on topic Brake pedal going almost to the bottom after lift
skywalker65 wrote: Have you checked the rear brakes are adjusted properly. Had all the symptoms you described after over hauling the full brake system on my Subaru Justy.
- Mart3971
28 Aug 2015 18:48 #150857
by Mart3971
Just ordered an easy bleed system and will look at the rear brakes. Did have them apart not that long ago and adjusted them up but not harm in doing it again.
Time to create page: 0.215 seconds
