Brake pedal going almost to the bottom after lift
  • Mart3971
04 Mar 2015 17:26 #139842 by Mart3971
Hi guys I have recently done a 2" lift. Pretty sure the brakes were normal before but now when the engine is off they pressure up lovely right to the top of the pedal. When I start the engine the pedal drops a good 3\4 before I get any resistance. I have blead them and all seems good. They do stop the car just worrying when you get so much travel on the pedal, doesn't fill you full of confidence when you need to hit them hard.
  • Longman
04 Mar 2015 18:44 #139852 by Longman
Did you fit a brake correction bracket on to the lsv
  • Mart3971
04 Mar 2015 19:03 #139856 by Mart3971
No not really sure what that is?
  • Longman
04 Mar 2015 19:09 #139858 by Longman
  • markyp2000
04 Mar 2015 22:14 #139889 by markyp2000
Replied by markyp2000 on topic Brake pedal going almost to the bottom after lift
The pedal will sink when started as thats the servo assisting the brakes the pedal shouldnt go to the floor with the engine running
  • Mart3971
26 Aug 2015 16:20 #150680 by Mart3971
Right i have fitted a new master cylinder and bleed the system a number of times and still having issues. Could it be the rear brake valve failing and causing the lack of pressure? Can i remove the valve?
