Extended Brake Lines
03 Mar 2015 10:22 - 03 Mar 2015 10:24 #139715 by Halford
Replied by Halford on topic Extended Brake Lines
kirkynut wrote: Would you be doing any off-roading where you may snag a brake line on a branch though Halford?
Also, if you lift it, your dog has further to jump or you have further to lift it. Just a thought having heard others talk about their dog not being ale to jump in the back because they have bought a higher car etc.
fair point, probably the closest I'll get to branches is the dog fetching them to bash my legs with, and then I could always use them to make a dog ramp :laugh:
does make sense though for proper off-roading, thanks for input guys, very interesting points Busta.
thanks Whaley, that sounds like a good find,
so how much longer should the lines be .... 3 inches, 4 inches, 5 inches ?
Last edit: 03 Mar 2015 10:24 by Halford.
03 Mar 2015 11:27 #139719 by Busta
Replied by Busta on topic Extended Brake Lines
I'll just add that no brake line is designed for snagging on branches or that kind of abuse, and to suggest one type is better than another is foolish. If you do get one caught on something, you need to check it for damage regardless. Reinforced rubber hoses can be visually inspected for cuts and swelling. I have no idea how you check the teflon inner of a braided hose for damage without removing it and getting it pressure tested?
03 Mar 2015 12:30 #139725 by X8GGY
Replied by X8GGY on topic Extended Brake Lines
Halford wrote: Money being no object, obviously S/S braid is the way to go but are they critical if you don't party like Jimny-Dave :whistle:
Hey! I resemble that remark! :woohoo:
  • Venter
03 Mar 2015 12:41 #139727 by Venter
Replied by Venter on topic Extended Brake Lines
I'd read what Busta has posted.
Just because it's shiny doesn't mean it's better... For application to 4X4s, probably actually worse in this case.
03 Mar 2015 12:43 #139728 by j999pre
Replied by j999pre on topic Extended Brake Lines
My shiny ones have been on 6 years.
Grey pick up Jimny
03 Mar 2015 12:50 #139730 by j999pre
From another website
In a nutshell, the stainless braided lines are stronger and do not expand under pressure so can give a firmer brake pedal. The rubber hoses do expand slightly so the pedal is not as firm. Typically competition cars use the steel braided hoses due to their performance and other factors. If designed to do so, you can remove them very quickly and not worry about clocking the hose, allowing you to change a caliper quickly. The rubber hoses are cheaper, so most road cars use them.
As far as what your friend said, no that is not correct. A quality teflon/steel braided hose (Earls, Aeroquip, etc) has a much higher burst pressure than a typical rubber brake hose. They flex about as well as rubber hoses.
End of quote
It would seem there are various theories? Suggesting one as definative maybe foolish. So I only give my opinion from experience but every day is a school day.
Grey pick up Jimny
Time to create page: 0.468 seconds
