the 1.6 is in but its not running properly
03 Oct 2014 18:10 #125657
by j999pre
Grey pick up Jimny
Replied by j999pre on topic the 1.6 is in but its not running properly
I agree. The one I did was jimny ecu and fuel pump in fact all the jimny parts apart from the injectors.
Grey pick up Jimny
- zuki andy
03 Oct 2014 19:03 #125664
by zuki andy
Replied by zuki andy on topic the 1.6 is in but its not running properly
Check the cam as the same amount of teeth for the cam sensor as the Jimny cam.
- supergaz
03 Oct 2014 20:11 #125669
by supergaz
Replied by supergaz on topic the 1.6 is in but its not running properly
Paint it silver, the blue is making it feel sick
- darthloachie
07 Oct 2014 15:58 - 07 Oct 2014 15:59 #125940
by darthloachie
Replied by darthloachie on topic the 1.6 is in but its not running properly
Its all running fine now
The timing was miles out and the plugs had seen better days
Its now running the Jimny coil packs and plugs (same same plug model number as the vitara) and has had on oil change and every things fine - the on road performance is much better than the 1.3 (especially as its a bit heavier than a standard jim) and we're all ready for the Jimny event now
Once we've got a bit more cash then the vitara exhaust manifold will go on and a custom stainless down pipe and cat will go on to match the back half of the system
Anyone need anything off the g13bb engine as its going to be weighed in?
Last edit: 07 Oct 2014 15:59 by darthloachie.
- Cider
07 Oct 2014 16:31 #125942
by Cider
Replied by Cider on topic the 1.6 is in but its not running properly
Great job
I had a similar fault with the coil pack, when I removed the connection lead "spring" from the spark plug to the bottom of coil pack it was very badly corroded
07 Oct 2014 17:37 #125948
by j999pre
Grey pick up Jimny
Is the head and cam up for grabs?
Grey pick up Jimny
Time to create page: 2.452 seconds
