the 1.6 is in but its not running properly
  • darthloachie
03 Oct 2014 07:27 - 03 Oct 2014 07:28 #125624 by darthloachie
the 1.6 is in but its not running properly was created by darthloachie
The g16b is in and fires up but when you accelerate it is missing, coughing and banging
The engine light is on
When its out of gear it splutters when you first rev it but it will rev at about 4000-5000 rpm OK but backfires when you let off the accelerator
when you drive it it just splutters and coughs as you accelerate but will then run smoothish at a constant speed until the engine goes back under load when it will cough and splutter again
It has the g13bb intake manifold and exhaust manifold, but the g16b injectors and coil packs
Any ideas what to look at ??
Last edit: 03 Oct 2014 07:28 by darthloachie.
03 Oct 2014 07:44 #125627 by j999pre
Cam sensor? Also swap your jimny coils and leads on just in case.
A lot of people use the green injectors from the baleno too? I did one for a friend and we used the baleno injectors but I don't know if it's essential
Grey pick up Jimny
  • Shima
03 Oct 2014 08:52 - 03 Oct 2014 08:54 #125628 by Shima
Replied by Shima on topic the 1.6 is in but its not running properly
Timing out by a touch? Plugs are in the right order? Which ECU are you using?
Also if you're close to a dyno maybe get it put on there and check the fueling on a wideband can tell you whats going on under load etc when on a dyno :)
Last edit: 03 Oct 2014 08:54 by Shima.
  • darthloachie
03 Oct 2014 11:40 #125633 by darthloachie
Replied by darthloachie on topic the 1.6 is in but its not running properly
Thanks guys
Using the jimny ecu
will try the coil packs and cables and check the timing tomorrow (it has had a new cambelt and water pump fitted before it went in)
are the spark plugs interchangeable with the g13bb? (as they were fairly new in the old engine)
if that doen't work will then will be looking for the green injectors (although cider said the vit ones were fine on his)
  • panosd
03 Oct 2014 13:21 #125639 by panosd
Replied by panosd on topic the 1.6 is in but its not running properly
You must replace the jimny ecu with the one from the 1.6
also check the fuel pump capacity. Your new engine require more fuel than the 1.3.
You are going to need the 1.6 fuel pump from the 1.6 gas tank.
03 Oct 2014 15:15 #125642 by Rhinoman
Use the Jimny ECU, the Vit ECU is completely incompatible.
Time to create page: 2.114 seconds
