Manual Hubs
  • JuanGuillie
20 Jan 2014 09:12 - 20 Jan 2014 09:17 #101222 by JuanGuillie
Replied by JuanGuillie on topic Manual Hubs
Did bought some manual hubs, find them very easy to use and i'm sure they are working properly when i put them on "lock"! :)
Driving on 2wd on highway and normal road's until we arrive to the meeting place for the road book (greenlane trip).
Before we start the road book i lock the hub's and leave them all day on and off we go, driving in 2-wheel drive.
When needed 4wd, stand still, put the little gearshifter into 4-wd, then only the front wheels will be powered trough the dropbox.
Once you passed the obstacle and if you don't need the 4-wd (high or low) anymore you put the little gearshifter back to 2-wd (always standing still), this disengages the frontwheels from the dropbox and the frontwheels run free again.
So you don't have to get out your car and you can leave the hubs "locked"!
After a good day of greenlaning and lots of fun, arrived at the meeting point again, i put the locked manual hubs back again in "free-modus". Simple as that.
I never use 4-wd on normal roads unless there is lots of snow on them and even then i like it more to drive the Jimmy in 2-wd, more fun guaranteed !
Fuel consumption will not be any different on a Jimny because all the system just do the same thing with manual or automatic hubs, could be i have some fuel saving, loosing the weight from all those vacuum pipes i took off.... :lol:
Last edit: 20 Jan 2014 09:17 by JuanGuillie.
  • Dave cc
20 Jan 2014 18:30 #101314 by Dave cc
Replied by Dave cc on topic Manual Hubs
Hey Kirkynut does anyone make them plates that they had on SJs that just let you do away with the FWH ?
Ive got a set here but i take it they wont fit onto a jimny axle without that adaptor plate hub spacer thing ?
Has got me thinking :) :) :)
21 Jan 2014 00:33 #101402 by Busta
Replied by Busta on topic Manual Hubs
If your automatic hubs work, stick with them and fit a 2lo switch (search for it in the forums). This gives you the best of all worlds- 2wd, 4wd, 2wd lo range all without leaving the seat. If you have extensive problems with the vacuum hubs then manual hubs make sense but if it ain't broke, don't fix it!
For me, the vacuum hubs offer a massive convenience and I'd be very reluctant to switch to manual.
  • jonesyba420
21 Jan 2014 08:52 #101413 by jonesyba420
Replied by jonesyba420 on topic Manual Hubs
Busta wrote: If your automatic hubs work, stick with them and fit a 2lo switch (search for it in the forums). This gives you the best of all worlds- 2wd, 4wd, 2wd lo range all without leaving the seat. If you have extensive problems with the vacuum hubs then manual hubs make sense but if it ain't broke, don't fix it!
couldnt agree more, ive got a 2lo switch. usefull if you need the slow speed of low box without the need for 4wd;)
21 Jan 2014 09:24 #101422 by robs5230
Replied by robs5230 on topic Manual Hubs
manual hubs not locked in will give the option of 2wd low range on the stick without any switch
standard jimny - for now
  • jonesyba420
21 Jan 2014 09:28 #101424 by jonesyba420
robs5230 wrote: manual hubs not locked in will give the option of 2wd low range on the stick without any switch
yep, however i can go from 4wd low to 2wd low without having to get out of the jimny B)
Time to create page: 0.425 seconds
