what welder
  • JerseyJimny
15 Dec 2013 15:28 #96142 by JerseyJimny
what welder was created by JerseyJimny
What's your budget?
  • JerseyJimny
15 Dec 2013 16:03 #96147 by JerseyJimny
Replied by JerseyJimny on topic what welder
An inverter would be best then....
Sealey
Carke
SIP
all good makes for a diy welder
And an inverter means you can also use it to TIG with a gas bottle
  • greenjimny
15 Dec 2013 18:14 #96187 by greenjimny
Replied by greenjimny on topic what welder
any 150 / 185 amp mig is well capable of that mate B) the trouble sometimes is getting them low enuff to weld panels :S
  • JerseyJimny
15 Dec 2013 19:13 #96202 by JerseyJimny
Unless you have been trained in the use of MIGs i wouldn't recommend a MIG
Its very easy to think you have a nice strong weld to only fall apart under load
Stick (Or MMA) welding is alot easier to create a strong weld and as long as the weld hasnt got massive chunks of slag in it you know you have a strong weld
MIG is too deceptive especially when your doing structural work like roll
  • greenjimny
15 Dec 2013 19:39 #96212 by greenjimny
a mig is a better all rounder (easy to use in tight spaces and capable of welding anything ) and lets be fair the welder is only as good as the person using it !
if your competent /confident with a certain type of welder then thats what you shld be using :)
  • JerseyJimny
15 Dec 2013 19:49 #96216 by JerseyJimny
The only point i am trying to prove is that if your self taught (not knowing yours or Mystics welding training) then you might be producing what you think might be a strong weld but is in fact simply sitting on the surface of the metal
Like this example of a MIG Weld that has been X-Ray Tested....
As you can see it may of looked a good strong weld from the outside but it hasnt even fused with the bottom plate!
Time to create page: 0.515 seconds
