beep beep beep
- Thank you received: 1869
17 Nov 2013 05:47 #91512
Replied by Lambert on topic beep beep beep
Oh that's interesting I never knew it ought to beep for the lights too. Is there a hack that can tell the bcm when and when not to beep? I am loathe to start cutting wires as I can see me upsetting the immobiliser with my luck. Are there any decent independent suzuki specialists in Yorkshire that have a good reputation?
17 Nov 2013 06:28 - 17 Nov 2013 06:29 #91514
by kirkynut
Replied by kirkynut on topic beep beep beep
Why not shut the door but leave the window open. That way you can hear your music & if it locks it's self you're not locked out. You also retain the lights on buzzer.
It just means changing a habit.
At least the car will remind you if you forget... beep,beep,beep....
Last edit: 17 Nov 2013 06:29 by kirkynut.
17 Nov 2013 09:32 #91524
Ok so I have had a look and it seems that whomever stopped the beep has done it by wedging the switch off with a bit of card and some tape :S I have put in back right for now till I get a better idea or someone to hack the bcm for me.
- jonesyba420
17 Nov 2013 10:41 #91536
by jonesyba420
Replied by jonesyba420 on topic beep beep beep
So basically the DEALER bodged it!!:ohmy:
I believe the actual buzzer is behind the dials.
17 Nov 2013 19:32 #91638
Mine has never beeped; only had it 4 months. :laugh: :laugh: Still, I'd like that facility. Is it cos it mine is an early vehicle?
Replied by helijohn on topic beep beep beep
Comes as no surprise eh!!jonesyba420 wrote: So basically the DEALER bodged it!!:ohmy:
- gaz3359
17 Nov 2013 19:44 #91641
by gaz3359
My interior light still works fine mine is a 2000 on an x plate.buzzer is located in the back of the clocks
Replied by gaz3359 on topic beep beep beep
jonesyba420 wrote: Gaz,does your interior light still come on when you open the drivers door? What year is yours?
Time to create page: 3.232 seconds
