beep beep beep
  • helijohn
17 Nov 2013 19:45 #91643 by helijohn
Replied by helijohn on topic beep beep beep
gaz3359 wrote:
jonesyba420 wrote: Gaz,does your interior light still come on when you open the drivers door? What year is yours?
My interior light still works fine mine is a 2000 on an x plate.buzzer is located in the back of the clocks
Is it a black box sort of floating about?
  • gaz3359
17 Nov 2013 20:31 #91666 by gaz3359
Replied by gaz3359 on topic beep beep beep
Its actually in the clocks a little black thingy best thing is to take clocks out then put side lights on you will hear it.
  • tackdriver
17 Nov 2013 21:44 #91710 by tackdriver
Replied by tackdriver on topic beep beep beep
Ths key in ignition beep is easily disabled by unplugging the connector behind the panel under the steering wheel. No need to cut wires etc. I found the guide on this site and it took all of 30 seconds on my 55 reg Jimny.
  • gaz3359
17 Nov 2013 22:24 #91734 by gaz3359
tackdriver wrote: Ths key in ignition beep is easily disabled by unplugging the connector behind the panel under the steering wheel. No need to cut wires etc. I found the guide on this site and it took all of 30 seconds on my 55 reg Jimny.
Not all jimnys have that plug thats in the guide mine hasnt thats why i cut the wire.
Time to create page: 1.764 seconds
