MOT Fail! - Brake Lines! :(
- Licksan
31 Mar 2013 08:48 #67387
by Licksan
Replied by Licksan on topic MOT Fail! - Brake Lines! :(
If I remove the auto brake adjuster and fit a T Piece would that fail the MOT and would it compromise the braking system?
The auto adjuster appears to be seized and as I never carry any loads in the back I can't see it ever coming into play so would be better without it.
- RichiesJimny
31 Mar 2013 09:08 - 31 Mar 2013 09:13 #67388
by RichiesJimny
Yes it will fail if you remove it and it probably won't make any difference to the braking but if its been fitted as standard it's got to stay.
It's there to reduse the braking effect to the rear wheels if you don't have any weight in the back to stop the rear wheels locking up.
Replied by RichiesJimny on topic MOT Fail! - Brake Lines! :(
Licksan wrote: If I remove the auto brake adjuster and fit a T Piece would that fail the MOT and would it compromise the braking system?
Last edit: 31 Mar 2013 09:13 by RichiesJimny.
- markyp2000
31 Mar 2013 09:12 #67390
by markyp2000
Replied by markyp2000 on topic MOT Fail! - Brake Lines! :(
It will make adifference to the brakes t may lockk up the rears and spin you round
- Licksan
31 Mar 2013 09:38 #67391
by Licksan
Thanks for the info.
As I have no back seats the rear is very light and it does lock up the rear wheels as the brakes are heavily biased to the front. Braking hard dives the nose and unweights the back end further! Got EBC Green Stuff pads on the fronts so they are powerful!
Time to create page: 0.453 seconds
