MOT Fail! - Brake Lines! :(
- Licksan
23 Mar 2013 11:32 - 23 Mar 2013 11:34 #66632
by Licksan
MOT Fail! - Brake Lines! :( was created by Licksan
Just failed MOT for corroded brake lines. The two that run down the chassis rails. Problem is toward the back.
Question is how much brake pipe do I need to replace ALL the solid pipe work on the jimny and what connectors are required. i.e size, type
Gonna use the non rusting copper nickel stuff.
Not looking forward to it in this weather! :huh:
Last edit: 23 Mar 2013 11:34 by Licksan.
- Smoggy
23 Mar 2013 12:45 #66636
by Smoggy
Replied by Smoggy on topic MOT Fail! - Brake Lines! :(
If I were you I would look at your fuel lines whilst your under the car. If they're dubious do them at the same time.
- GuardianAngel
23 Mar 2013 13:49 - 23 Mar 2013 13:51 #66641
by GuardianAngel
Replied by GuardianAngel on topic Re: MOT Fail! - Brake Lines! :(
The unions are metric M10x1 (male). Halfrauds do them. You will also need double flare ends on the lines.
Last edit: 23 Mar 2013 13:51 by GuardianAngel.
- markyp2000
23 Mar 2013 14:17 #66643
by markyp2000
Replied by markyp2000 on topic Re: MOT Fail! - Brake Lines! :(
Id clean them up see how bad the sreel pipe is ie pitted then paint them after the tester has seen them
Or take the pipes off take them to a garage and ask them to make some new ones upand then refit
- Licksan
23 Mar 2013 14:37 - 23 Mar 2013 14:40 #66645
by Licksan
Are all the unions male? Any idea how many I need?
Not fancying crawling under my car in this weather so if someone knows or has a nice warm garage and fancies a crawl under it would be much appreciated!
Marky, I know my tester well and he wouldn't fob me off so if he's not happy with the std steel ones I am sure they will be past it.
Got the bending a flaring tools to make brake lines just need an idea of how many unions and which type and how much pipe I will need. Is 25ft likely to be enough?
Replied by Licksan on topic Re: MOT Fail! - Brake Lines! :(
GuardianAngel wrote: The unions are metric M10x1 (male). Halfrauds do them. You will also need double flare ends on the lines.
Last edit: 23 Mar 2013 14:40 by Licksan.
- GuardianAngel
23 Mar 2013 14:43 #66646
by GuardianAngel
I got away with not having to do the front to back lines, but when I rebuilt the rear axle lines, the rear flexi hose to distributer line and one of the front caliper to distributer lines they were all male. I would hazard a guess you need about 10. They are cheap enough so maybe buy a couple of packs.
Replied by GuardianAngel on topic Re: Re: MOT Fail! - Brake Lines! :(
Not fancying crawling under my car in this weather so if someone knows or has a nice warm garage and fancies a crawl under it wos be much appreciated!
Time to create page: 0.232 seconds
