4w to 2w clutching problem
- pal911
21 Mar 2013 20:16 #66473
by pal911
Replied by pal911 on topic 4w to 2w clutching problem
I testes the 4w drive on à hard surface but wen driving straight with no turnings. Is that allowed?
- pal911
21 Mar 2013 20:18 #66475
by pal911
It is à push button
21 Mar 2013 20:35 #66482
by Halford
Replied by Halford on topic 4w to 2w clutching problem
testing your 4wd on tarmac in a straight line is OK
but there should be no noise at all and it should be smooth
there's something very wrong here :pinch:
maybe one of our experts can tell you what it probably is :huh:
- gus2000
21 Mar 2013 21:28 #66487
by gus2000
No, because the 4 tires have different radio (uneven wear, different tire pressure , different weights on the tire, etc .......)
This makes the same effect in the transmission as turning
Gustavo
Replied by gus2000 on topic 4w to 2w clutching problem
pal911 wrote: I testes the 4w drive on à hard surface but wen driving straight with no turnings. Is that allowed?
Gustavo
21 Mar 2013 22:19 - 21 Mar 2013 22:21 #66492
by gilburton
Replied by gilburton on topic 4w to 2w clutching problem
As suggested try it on gravel or off road somewhere. Push the clutch fully down! Don't try it on a road you can cause damage!!
Last edit: 21 Mar 2013 22:21 by gilburton.
- Basketcase
- Thank you received: 51
21 Mar 2013 22:30 #66495
by Basketcase
Replied by Basketcase on topic 4w to 2w clutching problem
I get that noise from mine sometimes it's something to do with the wheels being at different rotations said the Suzuki tech at work
Time to create page: 0.193 seconds
