4w to 2w clutching problem
- ZookFastback
should have said "for a short distance only, say 100m max, enough to test the system :whistle:testing your 4wd on tarmac in a straight line is OK
but there should be no noise at all and it should be smooth
personally, if you're looking to buy and it's clanking and clunking, I wouldn't :pinch:
- VAXXi
Halford wrote:
should have said "for a short distance only, say 100m max, enough to test the systemtesting your 4wd on tarmac in a straight line is OK
Actually, as I understand the Jimny's 4WD system, 4x4 on asphalt is just fine as long you don't turn the steering wheel and simply go straight. It's only during cornering when the transmission gets wind up and needs to release it by slipping the wheels.
No, because the 4 tires have different radio (uneven wear, different tire pressure , different weights on the tire, etc .......)
This makes the same effect in the transmission as turning
so I guess that would have an impact over some distance (maybe motorways or other long straight roads)
- VAXXi
All I'm trying to say is it's not recommended and you don't need to do it in the dry so why do it??
Rolling back and forward just to see if it engages is fine but personally I wouldn't drive more than a couple of yards/mtrs in 4WD
