New MOT checks
20 Mar 2013 12:43 #66373 by gilburton
New MOT checks was created by gilburton
I started off high and worked my way down ever since :-)
  • markyp2000
20 Mar 2013 12:54 #66376 by markyp2000
Replied by markyp2000 on topic New MOT checks
Not all of that is true plus how do you no the air bags working correctly my are bag light dont work so is that a pass or fail?
During an mot your are not allowed to remove any thing ie trims covers etc so
1 you cant check bulbs are fitted correctly
2 you can check pas fluid due to not being able to remove the cap unless its a clear bottle
3 head light adjusters aply to hid and led lights only
And theres alot more than this any way i will post pics of new bits in the mot later when im at home
20 Mar 2013 13:33 #66382 by mlines
Replied by mlines on topic New MOT checks
But the bulb failing (or missing) means it will not light up during the self test when the ignition is turned on.
So your Airbag light would fail due to its absense on turn on would be my interpretation????
20 Mar 2013 13:54 #66384 by gilburton
Replied by gilburton on topic New MOT checks
I also noticed a bit about seat adjustment. Does this mean fixed seats might not pass?? if they are not original??
  • markyp2000
20 Mar 2013 16:02 #66390 by markyp2000
mlines wrote: But the bulb failing (or missing) means it will not light up during the self test when the ignition is turned on.
Wrong its a pass the sequence of the bulbs doent come in to it any more if it not on its not testable
  • markyp2000
20 Mar 2013 16:03 #66391 by markyp2000
gilburton wrote: I also noticed a bit about seat adjustment. Does this mean fixed seats might not pass?? if they are not original??
It will fail if its ment to move it must move and lock in other position
Time to create page: 0.227 seconds
