Dreaded mot time!
- Skinhead
18 Feb 2013 15:57 #63018
by Skinhead
Replied by Skinhead on topic Dreaded mot time!
Take my advice and go to a different test centre
- JivingDaddy
18 Feb 2013 16:04 #63019
by JivingDaddy
Replied by JivingDaddy on topic Dreaded mot time!
WTF!!! Hard luck mate.
- ne-crock
18 Feb 2013 16:38 #63026
by ne-crock
Replied by ne-crock on topic Dreaded mot time!
so if i havent got a new sheet do you think if i take it back i'll get a retest, or will have to repay for an mot, if its a case of repaying i thinking i will go elsewhere for the mot,
i'm going to give it a strip down again and see what happens
would tyre pressures effect your brake balance?
- markyp2000
18 Feb 2013 17:55 #63031
by markyp2000
Replied by markyp2000 on topic Dreaded mot time!
I have known it on a few cars
If thay didnt refail it with a new failure sheet then you should get another retest may be a small charge
If you have brake imbalance remove the caliper and pad carryer remove the little 4 metal sliders on each side and clean the carryer and the sliders make shore both pistons are free make shore the caliper sliders where the 12mm bolts go through are free and the get some emry paper on a flat serface and rub the pads over it till it an even gray sort of colour
Use copper slip on the pads and normal grease on the caliper sliders a copper slip attacks the rubber dust covers
And reblead both front brakes just to cover that as well
Let us no how it goes
- ne-crock
18 Feb 2013 20:10 #63070
by ne-crock
I suppose remolds may not help then?
I'll give it another strip down tomorrow and see whats what
And give it a rub and grease
- GuardianAngel
18 Feb 2013 22:05 #63100
by GuardianAngel
I take it you dont mean copper slip on the pads themselves but the sliders :woohoo:
Replied by GuardianAngel on topic Re: Dreaded mot time!
markyp2000 wrote: Use copper slip on the pads and normal grease on the caliper sliders a copper slip attacks the rubber dust covers
