To fit Lockers or Not?
- Thank you received: 115
18 Jan 2013 12:54 - 18 Jan 2013 12:55 #58488
by maverick
As far i am concerned there are no downsides.
I used to have a Lockrite or Lock-Right in my non-Powered Steering SJ413 and when you accelarated it pulled to the Left and deceleration it pulled to the right (or the oither way around, can't remember as it was over 8yrs ago).
As Gaz says, you have 'change' your off-roading style with a Lockrite, as basically you always have traction through the axle from the Diff where the Lockrite is fitted. Without a Lockrite, you'd probably be using momentum (doing it fast, gunning thje trhottle) to get places, bt do that with a Lockrite installed and your gonna come a cropper! With a Lockrite you'll be amazed where you can get to with little 'pedal to the metal'
Add a RockLobster to the Lockrite with the front Hubs engaged ... go out and find that twisty and steep bank that you used to struggle with!!
I still stand with my first statrement - the Lockrite is the most effective mod you can make for enjoying your 4dx4 more
Do it, you won't regret it.
Now, the silly downside - get it fitted by a qualified mechanic!
Jalapeño, IISY?
Replied by maverick on topic To fit Lockers or Not?
Skinhead wrote: What are the downsides to the lockright apart from handling on corners? Im guessing wearing tyres down quicker, what about breakages?
Jalapeño, IISY?
Last edit: 18 Jan 2013 12:55 by maverick.
- TomDK
18 Jan 2013 13:04 #58493
by TomDK
How strong is it compared to ARB locker and standard Jimny diff?
Replied by TomDK on topic To fit Lockers or Not?
I still stand with my first statrement - the Lockrite is the most effective mod you can make for enjoying your 4dx4 moreDo it, you won't regret it.
- supergaz
18 Jan 2013 13:05 #58494
by supergaz
I agree, but I found it easy to install myself and I'm not a mechanic but I am a engineer, there is a write-up somewhere on the internet which I followed.
Off out now to play in 1cm of snow :woohoo: :woohoo: :woohoo:
Replied by supergaz on topic To fit Lockers or Not?
Time to create page: 0.244 seconds
