head gasket replacement costs?
  • DVs-Jimny
14 Oct 2012 10:30 #50217 by DVs-Jimny
Replied by DVs-Jimny on topic head gasket replacement costs?
Mine had a HG replaced, water pump and stat by the dealership that I bought it from due to overheating issues. However, it still did it if I gave her the beans and drove at 69mph ;)
As I had zero confidence with the garage (the tappets hadn't been set properly), I removed the rad and back flushed it. The water coming out with the rad upside down was a mere dribble. I fitted a new rad (came with new cap) and problem resolved. 18 months on and she's as good as gold.
Take the rad out, tip it upside down and see how quickly or not the water comes through. It's an easy job.
Good luck :)
14 Oct 2012 17:33 - 14 Oct 2012 17:37 #50234 by dirtydogz
Nobby22 had to replace his radiator when his jimny started to over heating same problem as DV-jimny.
2002 JLX Soft Top B)
Jimnybits 2" lift +Pro Comp ES1000 shocks.:) Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Last edit: 14 Oct 2012 17:37 by dirtydogz.
  • goatboy
15 Oct 2012 09:02 #50297 by goatboy
Replied by goatboy on topic head gasket replacement costs?
+1 for a new rad.
Mine was doing similar (but only in hot weather). New rad and all is good.
Your garage sounds rubbish by the way :unsure:
