Jimny Front Recovery Points
- Dutchjimny
22 Aug 2011 18:57 #20760
by Dutchjimny
Replied by Dutchjimny on topic Re: Jimny Front Recovery Points
hmm i get the point there.. so isnt out there anything universal for sale that you can weld/bolt on your chassis and cut a slight hole in the front bumper?
- X-Eng Simon
22 Aug 2011 19:18 #20763
by X-Eng Simon
Replied by X-Eng Simon on topic Re: Jimny Front Recovery Points
You do get threaded anchor bars, used in construction - essentially a bar with a female thread cut in one end that are normally set in concrete. The good thing about about them is they have a tensile rating. I would say this needs to be in the 10 to 20 ton range.
You also get male threaded eyes which are similarly rated.
This would allow you to drill a single, 20mm or so hole in the bumper to line up with the socket which could potentially be blanked with a colour coded plastic plug - much like the tow points on most modern cars - except a bit stronger.
We have a 3.5ton van whose towing eye works just like this. The blanking plug is so well camouflaged If you didn't know where it was, you would never see it!
Si
Si
- Dutchjimny
23 Aug 2011 14:23 #20791
by Dutchjimny
Can you post a pic of those anchors please?
- X-Eng Simon
23 Aug 2011 15:36 #20793
by X-Eng Simon
These are the kind of things:
www.alibaba.com/product-gs/457198530/ste...or_coupling_nut.html
Search for "threaded anchor coupler". You can get them up to about 200mm long.
An M16 thread is good for about 15 ton and M20 for 20 Ton.
Si
Si
- Johnniehec
- Thank you received: 56
23 Aug 2011 15:50 #20796
by Johnniehec
Replied by Johnniehec on topic Re: Jimny Front Recovery Points
I like this idea, see also ebay Item number: 370535130264 there was bound to be something on ebay!!
Pretty expensive but it is a whole box, word with a friendly builder maybee??
John.
John.
- X-Eng Simon
23 Aug 2011 15:59 #20797
by X-Eng Simon
Or go to your local builder centre - they usually have them individually. They often have screw on eyes too.
Si
Si
