Where's best to get a Lock Rite?
- gazert
10 May 2011 17:55 #16162
by gazert
Replied by gazert on topic Re: Where's best to get a Lock Rite?
Sounds shit times mate.
No idea tbh but hope u get it sorted!
- Bigchridy
10 May 2011 18:08 #16165
by Bigchridy
From the pics it looks like you have used the 2 big washers supplied with the Lock right. I have not used these. Instead I only used the 2 thin washers already in the existing differential.
Since fitting I dont seem to have had any big issues with the Lock right. I've had a couple of big clunks but the diff is still locking and unlocking as it should.
Hope this helps
Chris
Replied by Bigchridy on topic Re: Where's best to get a Lock Rite?
kenway wrote: I stripped my rear diff down again and found the pins had sheared again - see pictures...
Attachment Photo0083.jpg not found
Attachment Photo0082.jpg not found
After this I tried to contact through phone and email tech support but had no reply. As you can see from the rest of the pictures it is not worn and I'm stumped as to why this is happening.
This is how the pins and springs were inserted and the only pin which has survived.
Attachment Photo0084.jpg not found
Is it just an expensive paperweight?! Any help would be fantastic.
Attachment Photo0081.jpg not found
Attachment Photo0085.jpg not found
Hope this helps
Chris
- Bigchridy
10 May 2011 18:12 #16166
by Bigchridy
- kenway
10 May 2011 18:28 #16168
by kenway
Replied by kenway on topic Re: Where's best to get a Lock Rite?
I didn't use the thick thrust washer but did you not put in the spacer between the pinion block and the slide gear? This is where I may be going wrong. All information is helpful! Thanks for the advice so far.
- kenway
11 May 2011 14:16 #16201
by kenway
... so if I leave out the spacer that comes with the lock rite, will it not shear the pins? All help is welcome.
- Bigchridy
11 May 2011 18:46 - 11 May 2011 18:49 #16207
by Bigchridy
I followed that link exactly as I've never really come accross diff locks so thought I would get some advise 1st!
Have you been putting the square pinion joint back in the diff with the lock right?
The only 2 things I can think of at the moment are that either the wrong spacers have been used or the square joint has not been fitted.
Hope this helps
Chris
Hope this helps
Chris
Last edit: 11 May 2011 18:49 by Bigchridy.
Time to create page: 0.176 seconds
