Where's best to get a Lock Rite?
  • Bigchridy
29 Mar 2011 17:21 #14255 by Bigchridy
Replied by Bigchridy on topic Re: Where's best to get a Lock Rite?
gazert wrote: Just spoke to Adam and he has put his in today! He didn't have a spare diff either!!! And they had s baby last week!!!
Respect!
I'm gutted!:( I wanted to be the 1st to have it in and running!!!
Ah well maybe the 2nd then!:)
Chris
  • Bigchridy
29 Mar 2011 17:30 #14256 by Bigchridy
Mumbo Jimbo wrote: Thanks Martin - Received, much appreciated!
Don't think I'll be anywhere near as quick at fitting it as Bigcridy though, that's keen - even with a spare diff!
Cheers
Trevor
Fitting the lockright was easy. It's getting the half shafts out that I'm not looking forward to as I've never stripped the back axle of the Jimny.
On the link I've seen on here it shows that you have to disconnect the brake pipe unions from the wheel cylinders so you can pull the whole lot out. Does anyone know if this is the only way to get the rear half shafts out or can you do it another way?
Chris
  • bluejimny
29 Mar 2011 18:20 #14260 by bluejimny
Replied by bluejimny on topic Re: Where's best to get a Lock Rite?
i think it is im affraid, but dont worry about it, best thing you can do is wd40 the brake unions, and buy a proper brake union spanner, not an open ender, then ive got one of the one man bleeding kits, top up the fluid and pump away :)
  • kenway
29 Mar 2011 18:37 #14261 by kenway
Replied by kenway on topic Re: Where's best to get a Lock Rite?
Unfortunately, this is the only way of removing the half shafts. A good slide hammer is needed. I managed to sheer 2 prop shaft bolts and a crown wheel bolt but luckily once the pressure was released I managed to remove them and I had spare bolts from my old Vitara! Air tools make life alot easier! Good luck - I'm sure you won't need it!
  • bluejimny
29 Mar 2011 18:47 #14262 by bluejimny
ill second that, ive got the slide hammer from machine mart with the rear hub tool, works wonders!!
  • Bigchridy
29 Mar 2011 19:05 #14263 by Bigchridy
Looks like I best get the Jimny up to work then. I was going to do it at home on me back!:)
At least if I do it at work I have all the correct equipment there. Luckily all the unions are brand new as I only replaced the pipes at the back end of last year and the Jimny is off the road at tho mo so they shouldn't have corroded.
Chris
Time to create page: 0.169 seconds
