BigJimnyMeet 2024
Show us your flex
- gazwell
- Visitor
17 Nov 2011 22:55 #25990
by gazwell
Replied by gazwell on topic Re: jimny v6 trayback
thanks for that,the spec could be a bit long winded but theres not much i havent tweeked or changed!!
here goes : 2.5 v6 auto from a gv,pair of oddessy pc1500's,8274 with gp +3"drum+air freespool,gp h/d main shaft,+25%gears xp motor .rear winch warn xp with 8274 motor and modified rope retention system.
suspension arms kap h/d with polybushes all round, front arms extended 40mm,front axle is a modified sammy casing with chromoly 4340 shafts and cv's, modded arb to suit sammy shafts,diff is jimny ,rear axle is standard apart from arb and rear disc conversion.lowered rear top shock mounts and raised lower mounts (big jimny ones)custom rear winch tray with 2 swivel recovery points and ali tool box fitted behind under spare wheel.kap h/d panhard rod in rear,front one custom made (as i bent a h/d kap one).to rig up the jimny steering to the sammy axle i swapped the stub axle carriers left for right and right for left to put the part that the steering link bar rod ends go into behind the axle instead of in front, i then custom made a bracket to bolt on with the nearside caliper carrier to form an arm coming forward from the stub axle carrier to allow the jimny steering bar to connect to.inside is an arb h/d compresser and 1 gallon air tank to keep the 2 arb's and air freespool working nice. the rear tray holds 4 waffle boards,ground anchor(steel pin type for hard ground and hammer) ground anchor plough type,wheel brace,radiator/tranny cooler cooled by thermo controlled kenlowe fan. snorkel is ali linked to std airbox(sealed of course).
lights are 2 rear,2 rearside,2 front side,2 front spotsand 2 front fogs +headlights.bonnet is chequerplated in ali,as is the belly guard and front bash plate. i think thats everything!!! i cant take credit for cutting the cab down that was down to darren at kap who as you can see did a crackin job i got it back with just 2 chassis legs stickin out the back.all the rest of the work was done by myself.
- zukenutter
- Visitor
17 Nov 2011 23:00 #25991
by zukenutter
Replied by zukenutter on topic Re: Show us your flex
- X-Eng Simon
- Visitor
05 Mar 2012 07:51 - 05 Mar 2012 07:52 #34883
by X-Eng Simon
Replied by X-Eng Simon on topic Re: Show us your flex
Last edit: 05 Mar 2012 07:52 by X-Eng Simon.
- Sam_
- Visitor
10 Mar 2012 14:49 #35236
by Sam_
Replied by Sam_ on topic Re: Show us your flex
- Thank you received: 34
10 Mar 2012 16:05 #35239
by ooky_123
Former owner of Little "Ooky", who has now started a new life in Shetland
Replied by ooky_123 on topic Re: Show us your flex
Hehe nice one. You get get balancing on 3 wheels if you try a little harder ..
New tyres look good too
Now GET AND CLEAN HER !!!!
- Thank you received: 252
10 Mar 2012 20:11 #35254
by j999pre
Grey pick up Jimny
Replied by j999pre on topic Re: Show us your flex
Thats alot of travel and height SI. Looking good
Grey pick up Jimny
- 31zook
- Visitor
11 Mar 2012 03:06 #35257
by 31zook
Replied by 31zook on topic Re: Show us your flex
- Monkey
- Visitor
11 Mar 2012 09:09 #35264
by Monkey
Replied by Monkey on topic Re: Show us your flex
- blakey2000
- Visitor
11 Mar 2012 09:33 #35265
by blakey2000
Replied by blakey2000 on topic Re: Show us your flex
- doncarlyon
- Visitor
11 Mar 2012 09:44 #35267
by doncarlyon
Replied by doncarlyon on topic Re: Show us your flex
- Thank you received: 153
27 May 2012 20:53 - 27 May 2012 20:53 #41258
by supergaz
Replied by supergaz on topic Re: Show us your flex
Last edit: 27 May 2012 20:53 by supergaz.
- markyp2000
- Visitor
27 May 2012 21:06 #41262
by markyp2000
Replied by markyp2000 on topic Re: Show us your flex
Time to create page: 0.170 seconds
