hardness of the bolts for radius arms
- renard38
09 Jan 2011 11:16 - 09 Jan 2011 11:17 #9158
by renard38
hardness of the bolts for radius arms was created by renard38
hi,
I saw you have changed the bolts of the bushes ( for your radius arms ), cause those from suzuki are not good:
i would like to put like this: ( picture from Martin )
But what are their hardness???
Have you put 10 or 8,8 ????
( those from zuzuki are 10 )
Thanks for reply ( and i hope you will understand my very bad english :blush: )
Last edit: 09 Jan 2011 11:17 by renard38.
09 Jan 2011 15:22 #9173
by Obarno
Replied by Obarno on topic Re: hardness of the bolts for radius arms
Hi Renard
Your English is just fine - I wish I had the same amount of French! Anyway I use grade 8.8 in my Jimny and so far no problem. They are quite big bolts and the shear loading is huge so I think it very unlikely they would ever break.
The following user(s) said Thank You: renard38
09 Jan 2011 17:48 #9190
Replied by mlines on topic Re: hardness of the bolts for radius arms
I also used 8.8 as well
- renard38
09 Jan 2011 18:00 #9195
by renard38
Replied by renard38 on topic Re: hardness of the bolts for radius arms
thanks a lot
09 Jan 2011 20:47 #9235
by kirkynut
Replied by kirkynut on topic Re: hardness of the bolts for radius arms
Have you all been using bolts that are threaded their whole length?
I've been getting genuine £3.00 odd each Suzuki bolts as I could not find any others with the shank the right length and worried the thread would wear into the tube of the bushes - as I have seen happen to shock bushes on Landrovers when they used a bolt threaded the whole way.
I have been regularly removing each bolt and re-greasing them to stop them seizing and using thead locked nuts. Then I'll not have to buy new ones again!
Time to create page: 0.288 seconds
